That's awesome. Where did you get the shovel holder at? Could you provide more information on how you attached the box to the tunnel?Ridgid box from Home Depot. Think I paid like $25. Cut off the handle, and rip the plastic liner out of top. Replaced with foam.
Been beating on this thing for 2 years. One of my top 5 mods in my career. Waterproof, good latches, and the foam holds everything tight while riding.![]()
Sent from my SM-N976U using Tapatalk
Negative. I roll my sled probably a dozen times a day. Has never broke open by itself.Thought about the hard shell cases but shied away as I figured that they would tend to crack in cold / roll overs ...latches are def easier than frozen zippers but would need a safety to prevent unintended opening ...
Sent from my motorola edge plus using Tapatalk
Nanuk latches have a built in safety. (2 stage)Thought about the hard shell cases but shied away as I figured that they would tend to crack in cold / roll overs ...latches are def easier than frozen zippers but would need a safety to prevent unintended opening ...
Basically the same single stage latch of the early pelican.I've had great luck with my Seahorse 520
Likely. I have some Pelican cases as well and can see where ice could be an issue but the Seahorse hasn't given me any issues and the prices are better.Basically the same single stage latch of the early pelican.
