C
chevnrev
New member
So I have a 2008 M1000 with an OVS turbo kit, and I've noticed all of a sudden that if I am riding between 3000' to 5000', my pto side cylinder acts like it is not firing between about 3800 to 6000 RPM. If i flutter the throttle and get it to clean out and get above that it fires on both cylinders again and runs great. I verified that it's only firing on one side with my EGT's. If the Mag side is at 900 degrees the PTO side will be about about 400 and you can watch it just keep dropping. I use a Pure Logic fuel controller that came with the kit. I make sure to shut the sled down and start it back up every 500 to 1000' in elevation change to make sure that the computer is fueling for the correct elevation. I put in new plugs and it didn't change anything. Any ideas what could be going on here?
