i can tell you as of today we ran our tm1000 motor 9 hours on the engine dyno with our standalone ecu and with timming adjustment, you can run 9 lbs of boost at see level with 91 octan fuel with absolutely no fear what so ever.but once again, timming must be adjusted accordingly. the turbo kit we are using is a cpc kit(wich is by the way amazing fit !!)
I believe most of the issues are due to the extra timing advance in the mid-range on the bigbore 1000's that is built into the stock ecu, so if you can control that, you can probably get away with less octane. But without a det sensor, they are less forgiving than the M8's unless you are paying close attention to your tuning.
maybe the a/f pistons melt faster.
BUT, I seem to have some bad luck.
Sounds like you do have some bad luck, Fall down a cliff, blow up the sled. Man, that SUCKS. dont give up there will be good rides to come. I will agree w/the lean burn down. I deto an engine on a TM7 and the spark plug electrodes were burnt off. Good luck on the build. Might as well make her a 1200 with some boost.
Just for future reference Muriatic Acid and a q-tip work good for taking aluminum off cylender walls. Good luck to you.
