Ya you would think that the box could be checked and repaired... Would hope that PL would take care of that under warranty...
You can do a continuity test on your injectors... Put a Ohm meter between your injector terminals and measure resistance... Should see between 2.4 and 3.3 Ohms...
If you don't have a service manual check out sales@midwestmanuals.com It was about 12 bucks and is great to have.... Or PM me your email and I will try to send it to ya if you want, Good luck!
that piston sure looks like it should of made the jug very suspect???
good luck to ya
wow!
Get some egts. every sled I've ruined a motor in I could feel/hear it when it happened and never looked that bad. If you couldn't tell something was up either you weren't wanting to or something failed. I would say lean most extreme deto (I've seen) burns more toward the center of the piston rather than down.
At 11# are you running a intercooler, Might want to if not.
I don't know what the story is. I'm just check things over to find out why my sled burned down, and the resistance measures 11.1-11.6 in both primary and secondry injectors. I hope I'm doning something wrong, but I don't know what it would be. Resistance is suppose to be between 2.4-3.3 ohms.
Does this mean my injectors are bad? But all of them? Doesn't make sense to me, somebody please help.
I have to disagree based on my experience. My TM1000 has been plenty forgiving and I have run 112 up to 15lbs at 8-10k ft without troubles
Ya, pretty nasty ehh?
I thought about fuel again, but the other TM1000 I rode with last week was running the same stuff. Barrel was sealed, and i was the first to open it. I've thought about going back to sunoco, and maybe even up to 112 or 114?
But at 11# I should be good, or one would think.
I did turn the boost down a tad as well, and I turned up my yellow/blue to 4, up from the 1/2 where you had it.
I really think I need to change the box, like Garr said, if it's flashing blue at idle, something not right with it.
I don't know what else to say????? I jsut want to get this thing up and running so I can do sum riddin!!!!
These resistances are ok, the M1000 and new 2010 M8's use high impedance injectors - look carefully for any bad connections. I'm pretty sure you shouldn't be seeing a blue led at idle (means it's sensing boost?), so definitely have the box checked or replaced, and carefully check the boost sensing line for kinks, etc. The M1000's are pretty unforgiving, and 110 octane may not be enough at 11psi (better be good race gas) - with 110 I'd keep it down to 10psi, maybe less at lower elevations - what is your elevation?
