I am, I know that I am rougher on my sleds than alot of guys. I'm tired of spending $50 for a switch that I seem to break at least once a year, so I decided to move it. I had some ABS laying around and some time on my hands today.
You need to trim the stock cover
You also need to bevel the edge of where the kill switch normally sits.
I made this piece cutting the part that fits into the kill switch spot first. I then took a propane torch, heated the plastic and bent it down to fit the angle of the bars. Then I took the broken switch and set it on the plastic, heated it and then formed it to fit the angle of the switch, which is beveled. The nice part about this is the switch has kind of a snap fit when sliding it in to hold it.
Finished product, the hardest part was getting the cover to fit back on with the plastic in between the throttle block.
