Thunder Products Heavy Hitter Weights???
F
fast8seccamaro
Has anyone used the heavy hitters in the polaris pro? Ive had them on my cat 925BB and like how they load the motor and fairly easy to change the weight and tune. Any thing else I should be looking at?
I think Geo has some firsthand experience with them. I have a set in my tool box waiting for a day to test and tune. The profile is aggressive compared to a 10 series Polaris weight.
They'll get you a good holeshot for sure. Aggressive on takeoff so if your riding flatland style they would be perfect for you.
They're pretty close to stock profile and easy to balance with all stuff they provide. Some of the highest quality in the industry from my experience. No weird wear.
Not stuck with big mass changes. Some of the others require a minimum of 1 to 1.3 gr's at a time, HH'ers let you play with less change (.2 gr) if you want. What really sold me was being able to see an rpm difference with a small change. Some of the others have left me scratching my head with no rpm change after a large change.
Even though they have the "HH" name they are not biased to any part of the shift by mass or profile. You do that yourself if you want. You should end up close to stock Poo recommendation for mass at your altitude.
When I was stock gearing I had the HHer's with most of the mass in the heel and mid. After gearing down I moved some of that towards the tip.
At 5000 to 6500ish I run them at 68.2 with a 110-290 spring. Not a stock sled though. Built and piped for 7950 max on the way up and 7850ish when riding.
I started with the 58 gr base. With stock gearing I had to be creative with some lead so I suggest you get a set of tungsten washers if you are staying stock (Pro`s are geared way tall) for gearing or you may not be able to get the "mostest".
The instructions included should be a sticky on any set of adjustable weights. No easier way to explain what to do with all those holes in them there weights.
Geo- Ever run dalton adjustables? Not many people seem to use them or post about them, curious how they compare to the other adjustables.
I run the Dalton adjustables in two of my sleds but have never tried any other adjustables to compare with.
I have a set of Daltons in my box. Good quality too. Good profile. Easy to adjust.
Haven't retried them since gearing down. With stock gearing I found myself moving the set-screw up and down for the day. Deeper days 5 or 7 turns out towards the heel, less deep days back towards the tip.
