thinking about a viper
Nice comparo.
If you don't have a solid shot of cold air then please do so before you get into 2 feet of fluff. They will run ok without load and hot air intake, but you will certainly need the snorkel grabbing cold air under load. The left side vent is the best place without cutting a hole in your hood.
Best of luck
RS
I can tell you I am jones'ing for a new Viper 162. I am one of those, build it, bored with it, sell it kind of riders. Some sleds I have owned....2014 Pro Lite 153, 2010 M8 162 925 w/push race gas turbo, 2011 Doo 1200 mcx turbo 163,2009 IQR Carls 660 big bore 151, 2010 Apex Alpine Turbo 162, 2005 Vector powderlites/Alpine 163, 2007 RMK 700 155. Here's my breakdown for what it is worth.
2 stroke, light, fun, lots of work to keep a modded one on the snow. Proper wrench time will equal good hill times.
4 stroke, heavier only when stuck, lots of fun, anything less than 400hp is a turn the key and ride sled if put together by someone who knows what they are doing. Drive chains have been a downfall of the turbo 4stroke, much like tranys on hopped up diesels. If you don't go to a belt drive, change the chain/sprockets before every season for piece of mind. Even with belt drive, I would probably change after the first year, just because I hate to be towed.
Favourite sled in tight trees, Pro lite, turns on a dime. I have ridden the 162 Pro Lite, feels almost the same. You can set up a Viper to turn the same, probably better because of a little higher CoG.
I have spent time on a Boost-it 174 Viper. Loved it except for two things. 2014, so the lay down post is terrible, and the big a$$ trail seat. both taken care of for 2015. I haven't ridden any other Viper turbo other than the Boost-It kit, I can say I was very impressed with that kit.
Before I spent thousands lightening up a sled that really doesn't need it, I would swap the front suspension of the Viper. Either Skinz or BDX would be the best choice in my mind. I have ridden both, and both improve an already great chassis. Ski's, it needs them, my choice is powder pros, but that is very personal. Boards, tube boards, your preference.
I say go for the change. the chassis and engine are both great. once you ride 4stroke torque, even going to a well built, fast 2 stroke, you will miss the grunt.
Thanks for all the insights. I really like the idea of the Viper on boost. I know the Pro will be lighter. I have ridden the new cat chassis and when set up right they feel great. It sounds like you can get the weight of the Viper down close to the m8000 (stock) then the handling should be really close.
Perhaps next year buy the new Polaris (hopeful) [see how the axys motor holds up this year] for a light stocker and get the Viper for some boost.
Sounds like the hood and battery are the cheapest easiest to lighten it up. Any other big drops?
How are the running boards?
