Thermostat
Yup. Put it in a pot of water and boil it. See if it opens just before it boils.
It opened just fine. I installed it the same way as I have seen others install it w/out a bypass Have you guys been reading temps in the head or at the hose/Thermostat?
Anybody put a stat in an original (not Aluminum frame) KX500. The outlet from the head to the radiator is only about 1/2 inch apart. was thinking of eliminating the left radiator (would it over heat) or putting in-between the left and right radiator but I don't think it would work there.
Im riding a 94 kx 500 too. I removed the left rad. Then from the fitting on the head comes a temp sensor then a 180 deg.thermo bob then on up to the right rad.The bypass hose goes from the t-stat to the pump.The way that original left rad fits in there makes adding this stuff impossible.Yesterday was my first ride on this setup.I saw temps from 160 to 230 deg.Hopefully we can get by without that rad especially with warmer spring temps.
One other mod Im super happy with is a decompressor on the head.Larry Wiechmann did the head mod for me.Its a work of art and now its REALLY easy to kick.
Ya, it is a little hot for sure. But even with the new bob the max temp wont decrease.Its overheating cuz I only have one rad.At least it isnt boiling over.
This temperature thing might be challenging.
With the left rad in there is no room for a t-stat or a temp sensor.
With both rads in and no t-stat it runs ice cold.
i tried one rad on my cr500, couldnt keep it cool on setup up snow and warmer temps. i just put the other one back on and put valves on each side, one side has extra long hose that runs around the carb for heat. test it out this weekend and hopefully i have enough control over the temps
does it have a small hole so that there is some flow? without some the temps are head will be very hot and at the thermostat not warm enough to make it open
Yes, it has two, but they are very small.... like 1/16th inch. I may enlarge them.
With those holes in the stat you get plenty of flow to open the stats. You may just be overheating if it keeps climbing to 200F.
thats easy to determine just put your hand on the rad..f'n hot then stats are working, cold then not enough flow to get the stats hot enough to open
If he is measuring temp out of the head and before the stat and he sees the 195F then that stat is open. He already tested it and said it opened fine. He is just getting too much temp. Is this a FI bike ? Carb ? Jetted or fueled right ? Gearing ?What kinda snow condition. If your just running a hard pack trail then the bike can overheat.
I just threw it back on the bike, and now it's working like it is supposed to. When I took it out of the housing and was inspecting it, I compressed the spring a few times and threw it into the hot pan to test it. I wonder if it was sticking. Anyway, it works fine now. I also enlarged one of the openings, so that could def be it too. Thanks everyone for the help! It's nice to be able to get some decent opinions and how to on here!!
I'm thinking of reversing the flow through the radiators or relocating the bottom inlet to give more room for the stat. does anyone make a compact smaller thermostat?
