Here is what a ice racer from Sweden uses on his 500. He uses twin 55C stats. I think it will be to cold. I am in the process of fitting twin 70C stats in my 500. Would be more or less the same as what MtnDoo ran on his KX500 with no bypass. Gonna try it and see what i get. I still like Thermobobs idea and i think with a 1/4 bypass line it will work well. Still waiting for a good size housing from him though for a 70C. The 195F housing he currently has is to big imo.
90c just give him a call he can answer question he's been dealing with lots of snowbike guys lately
I have a cr500 and I'm planning to put a valve on the lefthand rad. and leave the stat with bypass on the righthand rad. I think that this with a temp gauge will be pretty effective. I'm looking for the best valve, small and compact, light.
I have a KTM stat now but it's in the way for putting a large desert tank on so i'm attempting to reposition it.
I have KTM thermostats on my 2012 KX 450’s and all I can get them up to in the deep snow is 120o max, most of the time they are under that. I think I am going to try pinching off the hoses on one of the rads. If that does not work I am going to eliminate the by pass on the thermostat housing and drill a very small hole in the thermostat so the hot water will reach it so it will open when up to temp.
Allen
Allen, are you still using the KTM t-stats? Did you drill a bypass hole in them?
Just curious as to what you've been doing to maintain temps on the demo fleet.
