Thermostat on a 2005 RT1000
I ve heard that it is beneficial:eek::eek: to put a thermostat off the 2008 XP on my RT1000 , I ve deleted the rear cooler and put a digital temp gauge on it, if anybody has done this could you sent me a diagram for the four outlets on the inline thermostat.
Do a seach on here and you can find the thread about it. Getting ready to do mine tomrrow.
Dooin mine, got all the parts except for a Y fitting, going to try and get a 1" to 1" with 3/4" off shoot from a deisel truck parts place. Hopefully I c an get it!!
Just went down to carquest and picked up a tee 1"x1"x3/4". If I don't like it then I'll try and find a Y fitting.
Did mine last week and i build a stainless Y for mine to keep the hose from kinking and kept it away from the pipe! for insurance i put some flex hose covering it to keep it away from the pipe! if you go to napa they have a block off plug for the small one that you don't use worked slick!
Rode mine on a 4 day'r 2 weeks ago and with Tstat ran flawlessly!!!! VERRY PLEASED
I ended up runnin the stock 800 T fitting put it towards the waterpump on the 1" rad hose, ran out a short piece of 3/4" to a 90deg automotive grade 3/4" elbow (from Napa) then a peice of 3/4" to the fitting on the one end of the T stat (the 90deg fitting eliminates the bend in the hose). Also from Napa got a 5/8" cap to neatly block off the unused outlet on the Tstat.
Cut the hose that goes to the head proper length so that the Tstat doesnt ride on the motor, (took me a couple cuts).
I need to throw one on mine, seems like it should really help as i can tell mine runs a tad weaker in the deep.
either way, RT's kick a$$!!!! power rocks!
Finished putting an '08 thermostat in my son's 2005 1000 Summit that he bought. Not to tough of a project. The most frustration was trying to get the conversion from the 3/4" nipple on the thermostat to mate up to the 1" outlet of the inline T that we installed. We also ended up using a brass 90° elbow to keep from bending the hose to tight and collapsing it. We need to find a preformed hose that goes from 1" to 3/4" and does a 90° bend that is about 8" long. This would make the project goe extremely well.
When he rode it for the first time yesterday and followed him in the 2-3' of powder, I knew right where he went by the black streak that he left. We're hoping that this will eliminate that and will let it run smoother and improve the longevity of the motor.
One concern I have with the project is making sure there isn't an air bubble in the system,when we're done. We filled the coolant res. to the top and raised the front of the sled to where the thermostat was higher than the rear cooler. We then ran the motor at about 3000rpm until we got the tunnel exchanger warm and it used about 1/2 of the coolant res. We then lowered the front and raised the rear and did the same thing. It lowered the coolant res. about an inch. If someone has a more efficient way to rid the system of air bubbles, please post it. We probably drained about a quart when we first cut the hoses and I feel that is what we got back into the system.
Good luck with it!
Good luck with it!
You should be good with the bubbles out. You might want to get the T from Doo as it is 1" to 1" with a 3/4" off. From the 3/4" off I ran a small piece of 3/4 hose to a 90deg (3/4 - 3/4) then a piece of 3/4 to the end of the T stat. The Doo T was fairly cheap as well. The 90deg is from Napa and is automotive (black plastic) coolant grade. This is a nice clean run. Both RTs did not have the black smoke trail just a bit at a take off. The one RT with a guage, temps were pretty consistant 105degs(seems to be the opening temp of the Tstat) and man does it warm up quick (suprising).
alright, i think im gonna have to get me a T-stat now, looks to be the ticket to getting em running realy nice. mine rips hard, but if that keeps it better i cant even imagine.
Do you have the part number for the 1"x1"x3/4" Tee that you mention? I used the Tee off of a 2001 800 that I am parting out and it is a 1"x1"x1" Tee. The thermostat skidoo stock #509000499 was great to walk up to the counter and ask for. Now if we just had the Tee stock # it would finish off the worries about what to order. Just a thought.
