I am in the process of installing the ktm thermostat on my fi kx 450 . I was told to just plug the bypass outlet but have some concerns about doing that. 1. When the thermostat is closed there is just a small about of coolant that will slip past the thermostat,will the water pump impeller build pressure causing seal failure, and cause cavitation leading to air bubbles...hot spots in head?? 2. Installing the thermostat 6 inches away from motor ,at the y in my coolant lines,with no bypass will the thermostat sense actual engine heat before engine get too hot. Have seen thermostats both in line, with and without bypass. Plugging bypass is simpler with less places for leaks, but if it works fine 9 out of 10 times....I am usually the 10th. Who has ran these and what works
