SUV Tire suggestions
Just got a quote from Les Swab for the Blizzaks for my 20's for 1400.00 mounted. They felt I could get 4-5 seasons out of them if only used in winter months. He also stated they turn into a AT tire at 50% tread. Seems like a lot of money for only that short of time.
That is longer than a set of studs. Studs last about 3 years, and then you have to re-drill and put new studs in (tire shops normally will never pull and replace studs). Many of the replacements will just be thrown or lay over after the first season. Don't get me wrong, studs do work on glare ice and snow, but you have less traction on a dry road compared to stud-less tires.
You won't get more than 3 years out of those. Most of my customers only get 2. They also don't turn into an AT tire.
I've never had any traction issues on dry pavement with studs.
I agree most studs get thrown, mostly due to being improperly studded in the tire shop. Factory studded are they way to go, Nokians being the best imo.
Traction on dry is not the issue with studs. They lose braking ability on dry. It's not horrible it's just not as good as a non studded tire.
I ran Yokohama Geolander AT/S rubber on my 99 Expedition and it did amazing in the snow with a trailer. I was extremely pleased with them. I heard reviews that the sidewalls were a little light for loaded 1-ton trucks so I have BFGs for winter tires on my F-350.
x2 on light duty but the soft rubber of em smoke off of a diesel 1 ton
So tell me this guys should I look for a 17" wheel instead??? If I'm ony going to get 2 seasons out of and its a arm and a leg for the 20" inch wheel. I haven't priced out the 17" wheel tire prices but I assume its a lot better.
Start watching Craigslist for wheels.
Yea was looking the other day and found a few. Does anyone know if a 07 tahoe could fit a 16" wheel?
Went into Les Swuab and their trying to talk me into the Toyo tires over the Blizzaks. A lot cheaper and same technology used. Anyone had good success with Toyo?
I would absolutely use the Toyo before the blizzacks. Had both. Toyos I believed were better all around. Slightly better snow and ice traction. Far better dry grip. Blizzacks felt spongy on dry.
Go to tire rack. Com
Enter your vehicle information and see if they offer a 16" replacement wheel.
Agree 100%. I would take the Toyo's over blizzaks regardless of price.
BFG A/T's and run 28-32 psi.
I have run (and installed and sold) almost all of the other brands of tires recommended. None of the other's compare for ride, handling (in ALL conditions, ie: snow, ice, dirt, rutted out freeways), and life expectancy. I can easily get 70,000 miles on a set. The only complaint I have with them is they tend to throw rocks a little if they are used on a vehicle improper back spacing.
The BFG rugged terrains aren't bad either.
Regardless of what the previous post says, the BFG Mud-Terrains do as well in the snow as the A/T's just not quite as good in the ice. They don't throw rocks like the A/T's but tend to get a little noisier as the tread wears. Still nowhere near as loud as a Super Swamper, Mickey Thompson, D.C, etc.
