Hi all. I’m coming off a 15 pro and have a 17 axys 155. It has fox float evols on the front, a fox zero pro fts and factory we clicker on the rts. I initially found I had way too much transfer and loosened the fts as much as I could. Still had too much and adjusted the rts tighter. Is this the only other option to control transfer with the fts as loose as it will go? I also find it very difficult to layover. Am I better off to have more or less air in the evols up front? I have 60 in the mains and 100 in the evil chambers. If I tighten the fts, will that help with laying it over. I would then need to tighten the rts more to control transfer. I’m 230 geared up. Thoughts? Thanks
