Brew, does that set up work on the 09's as well with the scissor relocate bracket? soft in the back and limiter in hole 3?
no. totally different.
Deaner, what track length are you? Our '10 154 was a wheelie king when we started out.....limiting what you could climb and having to turn out from excessive ski lift.
With the rear scissor brackets added, limiter strap in stock (3rd) hole, front skid spring very soft (that's important!), rear spring on #1 (220lb rider) and ski springs set soft (#1-2), this thing will climb a wall....very little and controllable lift and allows you to attack the steep stuff....and this with the Camo extreme hooking up a little harder than the stock track.
Yeah Paul, its a 154. Im 230 without gear. Limiter strap is stock. Rear spring was on 2 but it was WAY too soft. Have it on 5 now and it still seems soft but at least the back of the sled will come up a little bit when you push it down, Ski springs are set on stiff cause I like to jump. The only thing I have to check on is the front shock to see if I have it loosened up. Maybe my rear spring is bagged?
