B
biggsy90
2006 RMK 900 that is surging on light throttle. doesnt seem to be RPM related though always lower RPMS seem to take off then back down so on. at heavy throttle runs great. I just got this machine and have only ridden about 2 hours on it. initially seemed to run fine. Then I adjusted TPS and idles much better and reverse works well. I usually run at 9,000 feet and up. I checked the TPS with analog ohm meter and sweeps smoothly. TPS took me 1 hour to adjust to get to the .710 volts. it would jump from .8 to .6 just by tightening the screws, PITA. Plugs are new NGK BPR9ES. compression is good and equal, though I dont recall the number right now. has SLP pipe and intake and torque line head and 1,000 mile on motor from previous owner. Cleaned exhaust valves and has yellow springs. Temp runs low but seems to bounce around, one second its 95 then next its 110. never over 120 though. No bleeder on the coolant and no thermostat so i put it on the tilt trailer to bleed the coolant multiple times.
I have a new fuel filter that I am going to install, any other thoughts.
also I'm not sure how to check the REEDs
Thanks
Bill
Thanks
Bill
