Supercharger?
W
wilmot
I installed MPI Stage 1 Supercharger on my 2010 Nytro 162. What do you guy's think about the prologger gauge? What do i need to do to increase POWER? Any help would be much appreciated.
If you want more power, change the pulley ratio.
Call MPI and they will send you a new upper and lower pulley with more teeth on the bottom and less on the top.
But if you go more than a couple PSI your going to have to start looking at fuel delivery as well
Sent from my iPad using Tapatalk HD
I've got an AEM wideband on mine and an Autometer liquid filled boost gauge.
I had an AEM boost gauge on at first, thought it would be easy to read being digital, but found I was having to stare at it pretty hard to see it, so I switched to the analog gauge.
Much easier now.
I eventually would like to get a water and supercharger oil temp setup, but I'm not in a hurry because it works right now.
How much did your gauges cost? MPI recommends Prologger but its big and $700
not sure if thats the way to go.
Aem wide band O2 sensor is about 200 bucks off Ebay. A good quality boost gauge is about 100 bucks.
300 bucks will get you what you needs, no need for a prologger. Eric
Where do you mount 3 separate gauges? Do you have any pictures?
2 gauges, wide band air/fuel gauge and boost gauge. I made my own bracket. This was on my Apex. Eric
Zero lbs of boost :)
Sold the supercharger and Apex this summer. I ran it at 10lbs of boost.
Switched to a Pro after 20 years on Yamaha. Eric
Did you run 50/50 race gas or pump gas? I might get a pro for all the no snow days.
I ran pump gas, BUT I ride at 10,000ft +
Its funny you say you might get a pro for the low powder days, I thought that too. Reality is once you ride a pro for a day or two you never want to get back on the yamaha. I know, been there done that. lol Remember, this is from a 20 year veteran of yamaha only. I put enough money into 2 different apex's I could have bought 4 brand new pro's.
4-stroke boost is fun, and it will put a smile on your face but it flat wears you OUT!
Eric
Im sure the PRO is a nice light sled.But when there is 4 feet of heavy powder i will be happy on my boosted nytro's. Just purchased a MPI 180hp turbo for my 2011 163 nytro.
That mpi turbo will walk away from the super. It'll be interesting to see which one you like. After having both I say turbo hands down for overall. The super has its days but that's only the hard pack days.
I cant wait. Hope we have lots of snow this year. How does your 180 kit compare to your Impulse?
It doesn't. Kind of hard to compare 17lbs to 7. However, I think if you put on an intercooler and ran it at 14lbs it would be a heck of a lot closer for a ton less money. The Impulse is pretty wicked. A whole different animal.
If we get some early snow you'll have to give it a try before I sell it.
What is your next project?
