M
mike_s
Engine longevitiy on any newer ish vehicle really isn't a concern diesel or gas....Wouldn't really use that as a point of comparison.
This is true when the engine is run within the designers intended parameters. The minute you add aftermarket items you generally push it outside of those parameters. IE running higher RPM for extended periods might not be an issue with a gass engine, but put forced induction on top of that...an engine designed to run at 300 HP all day long wont generally be happy running at 450 HP for the same amount of time. Case in point: early GM vortech engines had a plastic rimmed "O" ring intake manifold gasket, worked fine when subjected to vacuum forces, however when subjected to pressure (read boost) they simply dont hold up for long. Whereas a late model direct injection diesel engine is intended to run with boost and everything affected is designed to handle the stresses added by it.
In my humble oppinion, unless all you tow is a pair of jetskis or sleds on weekends now and then, you couldnt give me a gasser to tow with. There is a reason that semis and transport trucks dont run extreemly big cube gas engines...
