My budget is tapped right now, but I'll hit you up later if need be and see if you still got it.
What exactly is the purpose of the chevy pump? Or should I say what does it fix?
It replaces the electric low pressure pump made by Facet with one of much better quality. There have been numerous issues with the pump made by Facet. Not just low or no fuel pressure but engines have had lean burndowns with continued running of the engine during low fuel pressures.
Originally in 05, the 1000 came with a pulse pump and was recalled for the electric pump in 06. 06's and 07's cmae with the electric pump from the factory.
So, you can run a Facet pump anfd take the chance on low fuel pressure causing possible engine runnability problems and burning down your engine OR you can upgrade to the E8012S pump and never have to worry about it again.
