Only with the extra long cable so it can be mounted on the ski loop so I can give myself a ski pull.I prefer the gold finger throttle.
Y'all have never been on a 200 hp standup jetski have you. Makes the nastiest mtn sled pale in comparison, and use triggers.The standard flipper gives more grip strength obviously. If you consider hanging on under accelleration, up hill all the forces are throwing you backwards and 4 fingers to hold on are way stronger than a partially open hand with only 3 fingers. Comiing downhill I agree a closed thumb is stronger but honestly this is not near the forces as climbing.
It's all about accepting the finger throttle guys [emoji129][emoji2532][emoji2380][emoji1787]
“All the sponsored dudes are running triggers now”Y'all have never been on a 200 hp standup jetski have you. Makes the nastiest mtn sled pale in comparison, and use triggers.
Also, have you even tried a trigger throttle or is this one of those self-feeling-never-tried-it posts? Cuz literally all the sponsored dudes are running triggers now.
How long did you personally try a trigger??
Try swinging a hammer with 4 fingers and no thumb on the grip vs 3 fingers and a thumb and let me know if you still think the flapper throttle has more grip strength..The standard flipper gives more grip strength obviously. If you consider hanging on under accelleration, up hill all the forces are throwing you backwards and 4 fingers to hold on are way stronger than a partially open hand with only 3 fingers. Comiing downhill I agree a closed thumb is stronger but honestly this is not near the forces as climbing.
Go chadly #197!!!This is why forums are so great! Someone brings up Polaris' unsafe throttle and now we got some guy arguing about jet skis. Pure entertainment ??? Now all we need is Terry's input. Does Terry's wife prefer the finger or the thumb??? ? On her sled of course...
From the email I got yesterday:So, now that Polaris says the Matryx throttle cable is unsafe and we should stop riding, what about the stock throttle block?
This is the largest and most obvious/universal safety issue on our sleds.
It requires certain conditions to become an issue.if this is a known issue how come i haven't experienced it in the last 9 years for riding. is there something different in the throttle block that i am missing ?
The 2022 throttle lever heater redesign makes it worse.It requires certain conditions to become an issue.
If u ride in those conditions constantly, it will be a serious matter. If u never see those conditions then it will never be an issue.
I've seen it happen on Polaris for a decade, while I rode cat without issue.
Been riding a Khaos since 2020, never had an issue because when it's deep I ride the Alpha. My buddies generally only have issues on the days I ride the Alpha. Lol
I also don't run the hardwarmers off trail much.
I like the look of the MVM and Skins throttle blocks.
thanks sheetmetalfab i didn't realize it was a diferent design , i was talking with my friend who has a matrix and he told me he was having issues with this alsoThe 2022 throttle lever heater redesign makes it worse.
