I wonder if adding more vertical play to the lever would be helpful or just add more area for snow to pack in?A trick a buddynof mine does is takes the flipper off and removes one of the washers from where the pin goes through
You’re right jet skis do need to switch to thumb throttle.Jetskis have been running trigger finger throttles for more than 30 years. Time to get with the times.
Dont see many trees or bushes on a lakeJetskis have been running trigger finger throttles for more than 30 years. Time to get with the times.
if this is a known issue how come i haven't experienced it in the last 9 years for riding. is there something different in the throttle block that i am missing ?Good responses flowing here guys.
I just don't understand why the known issue (since 2013?) hasn't been resolved by Polaris.
Yes we can find ways to mitigate the problem, but the sled should be able to run safely in deep snow with cold weather and stock hand/thumb warmers running without issue. This is not user error.
Sheeeeesh no one makes handguards and munster certainly does not make a guard specifically to guard from brush and tree impacts. Also, no one has a lanyard or anything. ??Dont see many trees or bushes on a lake
Sent from my SM-G991U using Tapatalk
Haha you were a cheatin hydrospace racer back in the day? Im still running sport spec on a wb1 and sxr for lites stock.I switched to finger throttle last season felt right at home after racing stand ups for 20 plus years. Going to get one for my slash soon mines iced up a few times and won’t idle down
Lol yup raced all the brands and tried to hold out as long as I could then gave into the hydro . Back on all kawis again one 1500 and one smoker 800 stock lites boat . The finger threottle on the sled was no brainer . Huge improvement on grip and controlHaha you were a cheatin hydrospace racer back in the day? Im still running sport spec on a wb1 and sxr for lites stock.
The standard flipper gives more grip strength obviously. If you consider hanging on under accelleration, up hill all the forces are throwing you backwards and 4 fingers to hold on are way stronger than a partially open hand with only 3 fingers. Comiing downhill I agree a closed thumb is stronger but honestly this is not near the forces as climbing.Sheeeeesh no one makes handguards and munster certainly does not make a guard specifically to guard from brush and tree impacts. Also, no one has a lanyard or anything. ??
You can dislike the trigger all you want. It gives 2x the steering control and grip strength of trying to use a thumb, and way more throttle input sensitivity.
Flapperfreeks is what i'll start calling yall.
