I have heard of people putting studs in the series 5.1 track. Has anybody done this out there? If so what did you use and do you have pics?
Well, I can make something for sure, the way the pro tunnel hooks into the bulkhead right there I would have to make /replace the complete tunnel sides or do like I did mine, then add a second overlay up frt to bridge ove the bulkhead peice..not a big deal other then the sled would pretty much have to be stripped bare from what I have seen looking at mine..price wise..what I did on mine ran about 5-600 in materials and powdercoating ...I put about 25 hrs into it for labor...I would guess you could double the labor time to overlay the bulkhead with the amount of stuff needed to be removed for access...
Shipped to Alaska?
he tore up his tunnel last spring right at the bulkhead..and wants me to figure out some reinforcments for it...Huh?![]()
Obviously the Comp Track and 5.1 are completely different, that was kind of the point. However if you put 1" screws, into a 2 1/4" lug, then the top 1" of the lug will not flex, therefore creating an unnatural bending point in the lug at the tip of the screw. I don't disagree however, that the 5.1 track can be modded, in small ways like cutting tips, to make it perform better for your particular riding conditions. The original question was about studding the track. My response is, that if you want a "studded" track, carbide screws in a Comp track, is a better option, for several reasons, than a 5.1, with true studs, OR screws in the lugs.The comp track and a modded 5.1 are completely different things. Even with the screws the 5.1 still flexs and If you are riding nothing but powder. Nothing but powder then a uncut 5.1 will be great but as lots have tried and tested a cut 5.1 with or with out screws will do far better is almost all conditions then A uncut or comp track.
Ouch I should have referred to the "experts" prior to wrecking all of these tracks! How on earth do all my sleds even get through the snow? A Christmas miracle!
