http://www.boost-it.ca/whats-new/2015/02/pro-rmk-engine-cooler/
Found this from boost it. Would this be enough and then leave the rear cooler?
Skidoo runs their cooler down just the middle, and used ones are dirt cheap. I wonder if it would fit in between the stock coolers.
I just ordered from CR, easy to order from the website, shipping cost was reasonable and it was shipped quickly, although that doesn't mean it will get here quickly. With the exchange rate right now CR is the best buy I've seen.
When yours shows up, I'd be interested in the weight / dimensional / alloy differences between the CR extrusion and the crazy mountain extrusion. Visually the CR extrusion has more external fins. The CM extrusion is 6061-T6 so it can be used as a stressed structural member where as the stock coolers are likely 5052 and do not aide in strengthening the assembly. IMO
I can do that. I think I can find a small piece of cmx to compare to.
