so i went through everything last night and still no luck. fuel pump works fine (tested with external power), i get 16v to the fuel pump when i pull it over, grounds are good, fuses are good. went through and checked all wiring and from what i can see its all good. i think my injectors might be stuck open because my plugs are always soaked and im getting a lot of fuel in my charge box. when i pull over the sled my fuel pressure spikes to max pressure and then immediatly drops. im not getting any lights on my fuel controller though either, checked voltage and only getting 5v when pulled over on the connector that powers the fuel controller. not sure if that is correct or what i should be seeing there. also put my ecu in my brothers sled and it ran just fine so i know that is good.
