Storage options for 154 expert
Blk88GT
Westbound and down
2,001
Winnipeg, Manitoba
With the shorter tunnel, I'm down the narrow Linq brackets and my "slim waterproof" tunnel bag no longer fits. Has anyone modified the bag to fit the wider Linq configuration?
Also - any recommendations on low profile bags that only use 2 brackets would be appreciated. I'd like to be able to carry fuel with me.
Blu Du
5,040
2,042
Nisswa Mn.
it worked pretty well just having the 2 straps around the back bumper but then i ended up getting the pro bag
Norona
2,589
4,688
North Vancouver, BC
www.noronalife.com
Blk88GT
Westbound and down
2,001
Winnipeg, Manitoba
Thanks guys, I ordered the brackets to make my slim bag fit. Also ordered the Pro bag but it's on backorder.
I'll have to take the tunnel bag and my buddy can take the fuel. LOL
Norona
2,589
4,688
North Vancouver, BC
www.noronalife.com
Just so you know two fuel cans wont fit on a tunnel, they are stagered , if you use the fuel caddy with the deep snow bag, the fuel caddy has to be turned around so the latch is on the left side, then the pro bag will fit, and so guys also know if you use the tool box the fuel caddy can be turned around as the tool box prevents this, then you cant run the bag, so do your homework on what you want. Things dont cross over as easy with normal tunnel to short tunnel.
D
Daner1978
132
86
Cottonwood Heights Utah
I run the BCA mountain pro bag, and that only uses one set of linq brackets. It would be super tight if you ran fuel caddy also. But that tunnel bag BCA makes it super slim and holds a ton of ****
