Stiffer Springs 2009 XP 154
B
BlackSummit
I am looking for part numbers for stiffer springs on the 09 XP. I read somewhere that any person weighing more than 180 should put the stiffer springs in.
Just had it done on Friday.
Here is the breakdown from Lynnwood Motosports.
503191251 RH spring $ 43.11
503191253 LH spring $ 43.11
Labor $ 59.50
Total $148.84.
Now, I am set on #1 instead of #5. I had to get the much stiffer springs because my total weight is me, backpack, and gas is 280lbs.
Since we have no snow, I will not be able to test out these new ones. But I will certainly let you know there is no sag anymore.
I just looked at the catalog and it says that spring is for these models.
Where Used: [503191251 (Paint Spring)]
Adventure V800, 2008-->08- Rear Arm Adventure
Expedition 550F, 2006-->08- Rear Arm
Expedition Sport 550F, 2007-->08- Rear Arm
Expedition Sport 550F, 2008-->08- Rear Arm
Expedition Sport V-800, 2007-->08- Rear Arm
Expedition Sport V-800, 2008-->08- Rear Arm
GTX 380F, 2006-->08- Rear Arm
GTX 550F, 2006-->08- Rear Arm
GTX 550F, 2007-->08- Rear Arm
GTX 550F, 2008-->08- Rear Arm
Legend Touring V800, 2007-->08- Rear Arm Touring
Legend Touring V800, 2008-->08- Rear Arm
Legend Touring, 2009-->08- Rear Arm
Lynx Adventure STD, 2009-->08- Rear Arm STD
weight on sled
It just depends on the amount of weight on the back end of your sled. The stock spring is for 175lbs, the next spring up is about 225, and the stiffest spring for the 2up and some those listed above is around 300. Since there will be some tension release in the first 10 hours or so, I went with the toughest ones.
