RideGuy
I was wondering if anybody saved the spread sheet calculator from the old forum. The input's were Gear Ratio,center to center, belt length, rpm, clutch diameter.... I think Krom posted it.....???
I lost mine over the years and am contemplating gear change if I don't go back to 57/63...... I loved the 57/63' but I see there are some serious options at Black diamond...... I'm just currious what the top end speeds would be with the 56/64 and other sets up to 52/68??
If I recall the 57/63's were in the 60's with my set up.... They were spunky gears.... till I rode early season without changing the oil in my case.....
I'm running the 60/60's right now working great but not near as fun blipping the throttle.... Climbs good and hold's rpm fine but clutch heat is more than the 57/63's....
Now I've been thinkng about this for a while... Rarely in the mountains do you look for top speed nor will you find a straight stretch long enough so what's the point of 60mph gear sets if you can't hold that speed on a climb.....???
So I'm just wondering how far you can go with the gear change before it's just dumb.....
T.I.A.
T.I.A.
