Sincere question,
The stock filter is 10 micron.. Why do you feel the 30 will do the job and not risk plugging the injectors?
I believe the rail fitting is proprietary. Not sure you'll have any luck... I've always removed one from the stockers.
Sincere question,
I feel 30 is going to be fine most car, dragsters and other sled manufacturer use 40 micron with not problems on fuel injection systems so why would it be a problem on the pro that uses the same type of fuel system but if customers want I could get a 10 micron cartridge for the filter assembly . I think your right on the hose end I have tried every where with no luck so far driving me crazy might have to just make it
Are these spi filters for a 13 and 14 also? Last I saw they only fit 11-12 Pro. Thanks
Ian
the filter I am using is 3 in long and 1.25 in diameter so almost the same size and should fit in factory filter holder
Has anyone found a 90 or 45 deg metal quick disconnect for the napa filter .
