So....what is covered in the powertrain warranty???
I'm getting mixed messages on what polaris will cover and what they won't cover on their 2 year powertrain warranty. Anyone one want to clear it up for me?
Thats not very comforting. Thanks for the reply though
2012 with 700 miles and bad injectors. the transferable warranty was the selling point over a modded sled.
Your injectors are covered! I am currently having a complete motor replaced under my 2nd year power train warranty. Just before the motor took a **** they replaced the voltage regulator under warranty.
No I am not. A bad dealer will find ways to make you pay for what should be warrantied. A good one will go above and beyond
If he has second year engine and bad injectors it SHOULD be covered.
SNOWMOBILE 2-YEAR POWERTRAIN WARRANTY
Powertrain Warranty Coverage Qualifications
 Coverage for powertrain failures due to defects in materials and workmanship will be determined by Polaris in its sole discretion. Coverage exists only for defects in manufacturing workmanship or material. Any non-factory authorized modifications void coverage.
 A $50 deductible will apply to each repair visit after the first twelve months of standard warranty coverage.
 The Powertrain Warranty applies to the first 3,000 miles or two (2) calendar years from date of purchase, whichever comes first. Tampering with the odometer shall void all warranties/service contracts.
 2nd Year Powertrain Warranty is transferrable, and the snowmobile must be registered in the current owner’s name to qualify for coverage assistance.
 Snowmobiles used for commercial purposes or for racing are excluded from coverage.
Powertrain Warranty Covered Items
Powertrain Engine
o Engine and internal components (including gaskets & seals)
o Exhaust Valves (excluding routine maintenance, cleaning, gaskets)
o Oil Pump (excluding oil pump lever adjustments)
o Water Pump
o Throttle Body Adapters
o Reed Valves
o Recoil (excluding rope)
o Exhaust Pipe, Manifold, and Silencer (excluding paint coverage and mounting hardware)
o Factory Installed Turbo Chargers
o Turbo Dump Valve
Powertrain Electrical and Fuel Delivery
o Throttle Bodies
o Injectors
o Fuel Rail
o Fuel Pump
o Stator/Alternator/Flywheel
o Voltage Regulator
o Capacitor
o Coils
o Idle Air Control (IAC)
o ECU
o Wiring Harnesses
o Fan
o Sensors - any sensor affecting the engine that provides an input to the ECU:
 Oxygen Sensor
 Roll-over Sensor
 Cam Phase Sensor
 Manifold Absolute Pressure (MAP) Sensor / Temp & Barometric Absolute Pressure (TBAP) Sensor / Temp Manifold Sensor / Absolute Pressure (TMAP) Sensor
 Throttle Position Sensor (TPS)
 Crank Position Sensor (CPS)
 Knock / Detonation Sensor
 Exhaust Gas Temperature Sensor (EGT)
 Engine Temperature Sensor
Powertrain Drivetrain
o Primary / Drive Clutch and Components (excluding weight / spring adjustments for altitude, normal wear and belt)
o Secondary / Driven Clutch and Components (excluding normal wear and belt)
o Jackshaft and Jackshaft Bearings
o Chaincase, Chaincase Seals and Internal Components (excluding chaincase lubricant change during maintenance)
o Driveshaft and Driveshaft Bearings
Powertrain Warranty Exclusions
Exclusions include anything not specifically listed in “Covered Items”, and are not limited to the following:
 Any other chassis or body items, not listed under ‘Covered Items’
 Damage due to accident, fire, explosion, theft, or other causes beyond Polaris’ control
 Damage caused by the failure of other components of the snowmobile
 Failures caused by improper fuel or oil
 Piston seizures, unless caused by a defective engine component
 Failures caused due to improper adjustments
 Failure due to unauthorized service
 Failures due to lack of service as required in the owner’s manual or Polaris updates. This includes off-season storage as listed in the owner’s manual.
 Failure due to use of unauthorized parts or modifications
my dealer is saying injectors are NOT covered under warranty.(They said they are going to try)
$249 for the injectors plus labor.
Gcmi, I did find that online but wasn't sure how old it was or if it applied to my 2012. Why would they tell me they are not covered?
Says right in the post that injectors are covered.
o Throttle Bodies
o Injectors ********
o Fuel Rail
o Fuel Pump
o Voltage Regulator
o Capacitor
o Coils
o ECU
o Wiring Harnesses
They do have to follow protocol on getting the warranty approved if not it gets rejected and then has to be resubmitted
