I Also tryed that spring...
I felt the sled trench more, and Harsher shifts
my .o2
Run stock secondary
When looking at Polaris charts for different elevations you see that the team Driven black/purple spring is good from 10,000-12,000ft but from 8,000-10,000ft they recommend the stock black spring. I bet the reason your sled felt harsh with the black/purple spring was due to the snowies ranging from 9500-10,500 elevation. I wonder if you were riding at 11,500-12,000ft range it would feel smoother.
it would hurt to run it one day and try it out for your self ... some people like different setup then others... IDK.. what works Best.. But i know what WORKED BEST for ME!
My .02
bring the spring for sure.. takes 20 mins to swap out!
I Have been runnig stock most of the year at 6 to 8k feet. But just went up to 8 to 10k on decent snow day. So i put 10-60's in. Pulled ok till i started to get higher on the pull and then i would some times drop to 76 or even 7500 a few times. Is any one else seeing this. If so what are you changing. Have been running stock set up springs and weights. i thought the 60's would be the trick.
