Put a brand new track on the sno scoot im restoring for my son for Christmas but no matter how much I loosen it off, the tension seems way too tight. It appears to me that someone may have moved the track adjusters further back on the rails because I notice a hole in front of the adjusters. im thinking they re drilled new holes further back on the rails to try to extended the life of an old tired and stretched track. I've attached pics here showing this hole in the rails right in front of where the adjusters are mounted and wondering if everyone else has the same hole showing on theirs? If not then I will know for sure someone has moved the adjusters further back on the rails, and in that case im gonna have a nasty job moving them back up considering all the tension on the rear springs :s without removing the whole skid.
So im hoping you guys can please have a quick look at your sno scoots and see if they have the same hole showing as in my pictures right in front of the track adjusters. if you don't then I know I gotta move my adjusters ahead and then I will be able to get the slack I need.
thanks everyone for your time
