Sno Bunjie placement
i just have mine around a large mtn addiction bag and just hooked to my gas rack,its been there for 500 miles so far holds great
Be careful with your gas can that far on your tunnel, try mounting it closer to your seat. If you get onto a rough trail there's a high chance you'll likely bend your tunnel a bit...
Found a decent solution ... removed the under hood spare belt clip holder (not needed) and tig'd it to a stub of pipe 1 size under the CF bumper pipe. ditched the end cap on the bumper pipe and slipped the stub end in and riveted kit in place. I notched the belt holder on the back end so that the bunjie handle is locked in place with front hook locked in the tunnel / board brace.
Easy and simple to remove and practically impossible to lose accidentally ... grab the handle, pull back and turn 90 degrees and it pops out of the holder.
As for the spare belt I have a crazy carpet (in case of need for tow) rolled up with the belt slipped inside and popped it in the same spot as the spare belt usually goes ... hood and side panels keep the rolled crazy carpet in place and same for the belt!
Also mounted a long handle axe on the back out of the way as well ... rubber loop keeps the handle in place and a short piece of bunjie hold the head in the holder.
I shoved mine through the straps on my handlebar bag. It's an old bag from about 15 years ago. I don't have pics, but any handlebar bag with velcro straps should be able to accommodate it. It's quick and easy to grab.
I've always carried mine wrapped around the bars/riser/mountain strap and hooked back into itself and never had an issue with that.. .and doesn't get any easier to access it . .
