smart phone app to turn phone into real gps?
Most, if not all, mobile phones can use GPS in airplane mode. It's just a matter of order. Activate airplane mode and it all turns off (GPS, Bluetooth, cellular, data) but then you go to your settings (or easier still, have a widget with toggles for these connection types) and turn on your GPS only. You are still in airplane mode, saving your battery because your phone is not hunting for cell signal, but all of your GPS apps track great.
As noted by others, you won't have data connection so cache your riding area while you still have signal. I use the app "my tracks" and it is great. I export my tracks and email them to myself. They are as accurate as my garmin 60csx GPS. So much so that I rarely download my GPS tracks because it is just so easy to have the phone email its tracks.
By the way, yes keep your phone away from your Avy beacon. They can interfere with your transceiver just like other electronics even when those electronics are off. Most of the trainers point out tests that have shown where even a powered off digital camera will interfered. Usually a foot or more distance lessens this effect but close proximitity is bad. In other words, do not but electronics in a coat pocket directly over, or near, your transceiver.
Thanks for the replies, I did load the back country navigator for 10.00. I loaded a forest service map. Worked very well.
I've used the Motion-X app quite a bit on my iphone. Last summer I turned it on during a few 15+ mile hikes and also took my Garmin to compare the two. They were nearly identical in every category when I stopped and checked them. It's pretty dang accurate.
I mostly use the free version of Locus on my RAZR Maxx. It has a lot of different map sources that you can cache when in service, plus you can points and tracks from quite a few sources. One issue that a number of Android phones have is that they use A-gps (assisted gps). I know my RAZR Maxx uses it. From what I understand, they use or try to use the network to speed up the gps performance . Sometimes I have to take it out of airplane mode in order to get a gps fix. That's fine and good unless you're really trying to squeeze out battery life over several days in airplane mode with no good charging source.
