Small throttle block for 11?
I have the rsi billet block. nice product. just make sure you pull out the throttle safety switch and tape down the switch and tuck it away in your bulkhead.
A little off topic: but can you remove the stock throttle assembly for the pro stock bars without removing the grips. Looking at putting the stock throttle control on RSI Burandt bars.
Would consider a whole RSI set up to keep from cutting up new grips and hand heaters.
No, just buy the throttle block from a Poo dealer and transfer over the throttle lever. Cost $40 and is part no. 5437688.
Have FUN!
G MAN
  • Like
Reactions: wjl
I did the easy way. I found two dealers and talked to them about the 2013 pro taper setup on the polaris.
The kill switch and throttle is separate and then you got room for handguards and can tuck the kill switch away down on the handlebars :)
Try Fastrax contact curt. He has a nice billet throttle block that he sells. You use your existing kill switch that mounts facing forward so you dont have to worry about accidentaly hitting the kills switch.
That sounds exactly like the RSI one - you sure they're not one in the same? Also the idea is stupid to me as I ride the trees and any forward facing kill switch is going to be a problem. Granted they have an o-ring on it but I use the same ring on my stock mount and have never ever had an accidental shut-off!
My 2 cents,
G MAN
My problem is not an accidental shut off but breaking the kill switch off all together. Think i might price out the 13 setup and go that route that way i can kind of hide the kill switch.
I really like the RSI one and checked it out real good at the snow show.. just not sure on the $90 price tag for it though.. :) I don't know why they would be out of stock. They had tons of them at the snow show and still had tons when it was over..
Sent from my Galaxy S 3 using tapatalk 2
Is the lever the same? I can't stand the stock throttle lever - too long!
Thanks,
G
throtle block
Catothom, did you buy the 13 bar and controls? How much $$? thanks, Doc
