My sled was doing something pretty close to what you are describing. Foul a plug or both plugs within 10 miles or 10' of the trailer. Replace with new plugs and she would run all day. Last time it happened it started and moved up one sled length in trailer and died. Had to pull it out of trailer by hand! We ended up replacing the injectors. Still ran a little crappy and found out the tps was set too low and then that the tps min max setting on the PC5 was not correct, we corrected yesterday. We believe all is now good. I will be in West Jellystone this Sat. thru Thurs. so I hope they are right. It sure sounds like injectors to me. By the way, I was under the assumption that both plug wires fire at the same time so there really is no wrong way to install them to the wrong cylinder. Am I wrong with this assumption?
I to was under the assumption that the plugs fired at the same time
Friend has a 12 Pro 163 Snowcheck
He had a few problems and all came down to a bad TPS sensor.
Sled has around 100 miles on it and it was just replaced and all seems ok.
Around 50 miles sled started idling really high or low, stumbling and lights flashing, no reverse. Dealer said loose TPS/fixed.
Sled idled fine and drove on trailer fine, Next trip, started dying, rough idle, lights flashing, no reverse. Limped back 10 miles to cabin.
Returned to same dealer, TPS replaced..Seems ok now.
Time will tell...
Replaced probe and rode it to the timeshare. Let it sit for over an hour at 10 degrees and fired the girl up and rode her! I sure hope it's fixed, tomorrow will tell for sure. I will post if its fixed or still a problem.
When my probe went bad I chased everything to the point of replacing injectors checking and testing tps and checking every sensor on the sled to make sure they met factory specs. The pipe temp sensor test gave a specific ohm reading for the temp sensor if it was at a certain temperature. I tried to reach the temperatures specified and experienced continuously moving ohm readings, so I checked the sensor when it was at room temperature after an hour of cool down and the ohm readings kept cycling greatly on the ohm meter. When the sensor is at any temp the ohm reading should be stable not continuosly moving drasticaly on the meter. I have been told that when a pipe temp sensor fails the ecm sets a code, but on mine it didn't as it was still reading. Just my findings.
Suggest they replace the exhaust pipe sensor, even if it hasn't set a code. I'm not garanteeing that is the issue, but it has happened with the Dragons that the sensor was bad and didn't set a code/turn on the light.
sled_guy
Well sled went through 3 sets of plugs to get the three blocks to West Yellowstone Polaris. After tearing apart the sled the injectors look like they have all the o-rings but.....the VForce III reeds are all chipped up on the edges and not sealing. Going to have service install the stock reeds and try it again tomorrow morning. Wish me luck!
my vote is for the spark plug wires arcing out on the head or head bolt.. seen this on my 2011 too.. heard of it on the 2012 as well... check those close, maybe put some fuel line hose over them on the contact points.. thats what we did..
i have seen this happen on a pro with a stage three kit on it i dont know if it fouled a plug butter it wouldn't rev over 7000 it would just fall on its face turns out the guy was running to much octane and the fuel couldnt burn fast enough
