Busy pouring Concrete. Wil get to pm' s when get time.
Not me. Bout 600 milesAnyone crack an updated slp pipe?
The updated pipe has a "X" welded across the egt bung. EricWhat is considered an updated pipe, just the extra band or the band and the weld tying the pipe to doubler to bung?
looking for suggestions.
Should I go for a full SLP pipe and can or just a Diamond S can.
looking for the best bang for the buck.
I like the substantial weight drop with the diamond s can, but like the performance gains of the slp combo.
SLP looks to be about $120 more before clutching
I will probably go turbo next year, so would be selling which ever i choose
thanks
I did both last year. I am now running the SLP pipe into a Diamond S can. The sled works great with just the can and you do get a lot of weight loss. However, the system with the pipe and can really works good and you lose a little more weight too. I have the Carl's helix running stock springs and 66 Belly Busters. I like it a lot. The helix can be run in two different settings too. I have tried it in the steeper ramp. I will run the other ramp this year. It is a little snappier in that ramp and pulls higher rpm.
hi all 1st post ever!! hope this works. my ? is that I have read not just slp pipes but most pipes 4 the 2016 axis 800 have hade a tendency to get hot and hit det.. after a handful of long hard runs up the hill...have u found this 2 b true? if so is it just a madder of adding some vents \extra air flow under the hood? I like slp pipes (only pipes I have owned were slp or cpi )but I'm open 2 what ever set seem 2 complement the motor and not compromise it. I ride the mountains and have ran twin pipes and found they burn pistons a lot more frequently when held WOT for long periods so the power gain just is not worth pain! if any one has any thoughts about other pipes on the 800 ho motors I would pumped to hear them !!! thanks
thanks eric my understanding of the newer sleds is just stating.im used 2 porting , smacking a pipe on, a hi flow intake and some jets in the old carbs....if N-E-1 remembers what those are ...then adding weight 2 the primary 2 get the RPMs back down!! so I live in Alaska I start riding at about 3000 ft top at around 10000 give or take would the lower elevation need a higher octane? was thinking about running RK TEK heads and pistons whith the pipes...u think that would caus problems? I just don't understand all the electronics..det sensors fule maping programmers just don't want to get to deep in2 s#i* that I don't understand yet...loved it when a 2stroke was simple but cant complain about the horsepower they are putting out!!!thanks 4 the help.
Do I remember jets.... Ah yep, and porting, reeds, boost tubes, billet heads, and then top it off with a 45hp shot of N20. And then burn a piston 2-3 times a year if you got bad gas or the temps dropped 30* when you where out riding.
Dont miss those days at all. I do think that big of swing in riding conditions may present a challenge. These sleds do have 2 fuel mode, Ethanol and Non-Ethanol.... That does give you a little adjustment, Ethanol mode is going to give you about 5% more fuel. The SLP pipe kit does come with a resistor to install into your EGT sensor that tricks the computer into adding more fuel at higher RPM.
There is some good tech info in the Alaska riding forum. I know several guys running slp pipes on axys's in alaska. I would check there.
I dont think adding a head and pistons would be a good choice for you. Eric
Eric, so you plug the resistor into the EGT and leave it in there at all times. then based on availability of fuel, I can change fuel setting (ethanol or non ethanol) on the gauge cluster correct?
thanks
