I actually over-rated the payload. Here are the payloads as listed by Toyota, hence the only reason I drive a 1 ton truck.
The warranty on my 6.0L Ford is just about to run out and after $21000.00 worth of mechanical repairs (under warranty) it is time to look for a reliable truck. I just wish Toy's payload was higher as they make great trucks. I just do not want to go back to hauling a trailer.
4X4 DOUBLE CAB SR5 4.7 V8 5A STD Payload kg (lbs) 565 (1,255)
4X4 DOUBLE CAB LTD 4.7 V8 Payload kg (lbs) 580 (1,285)
4X4 DOUBLE CAB SR5 5.7 V8 6A STD Payload kg (lbs) 630 (1395)
4X4 DOUBLE CAB SR5 5.7 V8 6A LONG Payload kg (lbs) 615 (1365)
4X4 DOUBLE CAB LTD 5.7 V8 Payload kg (lbs) 645 (1430)
$21k for repairs???? wow, that's a write off .
wtf was wrong? complete drivetrain including motor?
It doesn't take long when it takes 8 hours to replace a belt on the 6.0. What doesn't go wrong in a Ford?
My truck still takes all my money but it goes to mods, not repairs!
thats embarassing for payload. my ranger has a payload rating of 1240.
Was thinking it would be on the edge just thought i would see if some one tried it.
thanks
I'd be more concerned with the brakes. The brakes are rated for a certain weight, put more than recommended and you may overheat and burn them up. Especially in the mountains.
Although weight ratings with 1/2 tons will be at/near the edge, I promise brakes and axles are NOT a concern in the Toyotas. 07+ Tundras have beefier brakes than F350's....you need 18's just to clear the rotors, even the rears.
A couple friends of mine have decks on Tundras, I'm sure they're right at the legal limit or over, but they handle awesome. Needs airbags to ride level, but so does an F250
Have you driven both and still hold that opinion? I highly doubt it....And Tundra still can't haul or tow as much as a 150. You would think with all the "beef" you talk about it would be a different story?
