if you have a truck shop around they make cool little round led light that all you have to do is drill a hole put in grommet and shazam, sweet and clean. cheap too about 7 bucks a light and you dont have to worry about snagging them or burning out they lay flush. i use them on equipment underground and this stuff gets beat
are you building this for a short box or long box?
also what size steel are you using for everything?
very nice looking deck! About how much steel did you have to buy? How did you endup coming out on weight?
what is the weight on it?
looks good, I want to build one for my short box. Would you happen to have some designs for a short box build?
Looks almost identical to the one i made. After having it and using it things i would change.
1) Not run Angle iron inside of the supports but rather run angleiron INSTEAD of the supports on the main deck.
2) Not so many crossmembers on main deck. Will make it lighter and really not needed. A 2place trailer has them like every 2ft or 2.5ft
3) Make beavertail shorter (sometimes the rear of the ski will fall through when unloading)
4) Make a tie down in middle of deck to be able to haul 1 sled.
5) Have sled deck tie downs on outside of bed and use tie downs made for Camper's. Sucks having to crawl inside to undo your deck.
Here are the plans I have drawn up. Do you see anything that you would change or suggest ?
Top support view
Back view
Side view
Front view
Ramp
