I've got a 19 tooth gear and nobody up here can tell me whether I need to put a new chain in or if the stock chain work, I've had conflicting stories, 21-45 stock, My dealer has not done one yet, thanks dan
if you don't care about the chain breaking or loss of HP.. stay with the larger chain.. what you need is the 102 chain
What chain do the 146's come stock with?
Are all 146's stock with 23 tooth or 21 tooth tops?
I did the same today, easy swap, slight kink in the chain with the smaller gear but I've seen worse in the old polaris days. From what I've been told even though you are gearing down , you gain a bunch of track speed. I've added more weight, up to 16.6 grams on the pins and now the gearing, hope it works good,
Yep, ran the 16gram weights (team pin kit) and was on clicker 4. Pulled 8100-8200rpm all day. Track speed anywhere's from 42-45. Still need a little less backshifting though. I bought a 44/33 helix and a 20 tooth gear. I will let ya know when my driver breaks again.![]()
