In this vidya, I give you a shortcut to what the angles of ramps can do for you, your situation. I did much of the trial and error for you to figure out what the curves and angles can do to the conduct of your clutch tune based on your application. The following videos are a model to help you prepare mentally for what you are going to experiment with in clutch tuning. Now you go take action and try different clutch ramps to gain the skills on "reading clutch ramps".
I had to go here with the TRA first so that you can see the pDrive works on the same principles and tear down the b.s. that because they are different clutches, that one is harder to tune than the other. Does not matter if its a golf cart cvt...same sh|t, different brand.
thanks
click "full screen"
thanks
click "full screen"
