Silber on 2013 how to adjust boost
Silver boost dial has + with arrow. If you turn it back all the way does this mean no boost
If you turn + one complete turn does that equal to 1 psi
Want to make sure i have proper psi
If you dial it all the way closed it will make the boost pressure that is set by the wastegate actuator spring which is 7 pounds or so. The way they work is by bleeding off pressure allowing for more boost before the wastegate opens.
Riding sled this weekend at 1000ft very carefully before heading to Revy friday
50/50 race fuel. Got dial 3 full turns. Or 3 psi. I think thats right
What should i set all my settings to be safe
So, as Corey said unless you change your waste gate actuator spring the lowest boost setting you can get will be around 7psi. So in short, 3 turns out from the lowest setting on the dial does not equal 3psi on the gauge. It will likely be around 7psi unless you changed your waste gate spring.
you wil be to high of boost setting it that way. all the way closed is 7 lb 3 turns would be 9 or 10. Running at 1000ft is dangerous at 9 lb with 50/50.
You have the 7psi waste gate in it stock. You will have to buy a 3-4psi waste gate otherwise you WILL NOT be able to run under 7psi boost at low elevation.
