Issue not solved. Yes TSS is unplugged.if you unplugged your handlebar harness and it solved the issue it has nothing to do with fuel/reeds/chassis harness etc. just to be clear you removed the TSS switch and unplugged it?
did you unplug the handlebar harness like suggested? no change? does it always cut out before the clutches engage or can you "creep" it along?Issue not solved. Yes TSS is unplugged.
HI all . God I'm no mechanic!! How the hell I missed this is beyond me. I started it and gave it till right before it would normally shut down and went back and forth with throttle. I noticed the whole clutch was moving I shut it down and looked down there is a crack on pto engine plate mount, I pulled primary and 2nd off and the plate was shattered. I ordered a new one today I'm pretty sure that is the problem. I'll update when its replaced. Thanks for all your time/help guys.did you unplug the handlebar harness like suggested? no change? does it always cut out before the clutches engage or can you "creep" it along?
Thanks I'll tear back into it today and check grounds .Check your grounds, after the engine torquing around, something else may be loose or broken. I had a similar problem and it was because the chain case was broke off where it bolts to the frame spar, there is a ground wire there and it would die when it would flex.
