DUDE!!!!!! Look at your primary clutch !!!!!!
You are burning the living sh!t out of the belt.
you need a stronger secondary spring, and your helix starting angle is to high.
a Mountain 900 needs a flatter starting angle and more spring.
try a 60/42 - .46 and a 160 X 300 spring with a delrin washer.
The 66/44 - .42 your running will work in a flatlander sled with the a weak spring but NOT in a mountain sled with a track that long.
Your front motor mount problem is a result of clutch troubles more then anything.
Dan
Dan, the clutching is fine right now, and was all last season. What happened is when I got the sled back from the first dealer I had work on it, we re-used the stock Polaris primary spring .... If I remember right, it was a red/black spring.
With the 66/44-42 helix and the stock secondary spring, the clutch was not shifting out all the way. The stock polaris red/black spring had much too high of spring rate. ...
I had all the rates and whatnot written down, I dont remember them off the top of my head, but the bottom line was that when I compared what the stock yellow/green spring on a 2003 900 Mountain Cat was, it was like 60 lb/in less or something along those lines.
As soon as I put the yellow/green spring in, everything was fine.
I can ride deep pow on it for hours on end, pop the hood, and hold my hand on the belt ..... The belt is not getting very hot at all now.
I should have removed the clutch and cleaned it after the Polaris primary spring mishap the season before last, heh ....
