or you could pony up?![]()
I just did this tonight, I had a longer piece of 1/4 rubber hose laying around so here is how I routed mine to the bottom of the chaincase.
Here are some more pics of the VES drain line 'moveage'. I did this last night. Right now it is set up to drain into the chaincase hole but i might drill a hole, throw a grommet in and zip tie it so it is going directly out of the bottom.
Justin
To prevent the track edges from fraying.... Grind or file the back edge of your drop brackets right where the track comes around and goes up into the tunnel.
These edges are real sharp and when the track shifts from side to side this is where it will rub.
Stupid question, but what is the best place to get heat tape? are there different kinds? if so what kind should i get for covering my side panel near the can?
