savedbygrace
Post your opinions and/or theories of operation proudly below.
Experience may be helpful…
Junior
Junior
Junior
Junior
This is a sincere question... so don't take it the wrong way Snowstar... I am always intersted in innovation... and open to learn more as these turbos evolve.
How much transistional-throttle full-load work were you able to get in your testing on the the TT-D8? Were you able to spool it up, snap the trottle closed and get back into it multiple times in the same pass?
Can't wait to hear how it works on the snow.
The shortest distance from A to B is always best.... Also the straightest path would be beneficial as well...With that said some of you savey turbo guy's need to build a turbo that mounts directly behind & horzontal to the carb rack. This could be made possible by 1st designing a smaller gas tank to allow for the room to make the install possible. The cold air intake would externally be mounted just infront of the riser bar for optimum air intake and the exhaust would dump out under the tunnel and would require a deflector for those deep powder days.
OT
Ok now how about the length of the exhaust tubing on the twisted kit? More volume to pressurize before the turbo will spool would this work against the throttle response?
My own experience with my IQR1000 turbo (M1000 motor) is that the shorter charge tube increased throttle response and overall ridability of the sled. My charge tube is about half as long as the standard TTM1000 charge tube. The new Twisted Polaris that I rode yesterday had even better response than my sled. No sales gimics here just honest experience.
