I hear ya about the justification... POST purchase. Regardless of outcome. This is true for inexpensive stuff and really expensive stuff... Hard to tell your spouse that you can't take the kids on a vacation this year because you bought a turbo or set of shocks... or a new sled for that matter.... Even harder to tell them that the item you bought doesn't work... Hard to tell yourself you've been foolish with your money, and if you have friends like mine, they'll tell you just HOW foolish you were if you don't justify it.
I have used the Float3 on my PRO last season... and really liked the adjustably of spring pressure.
A lot of people may chime in and say that they had an issue with floats... but may have used them over 10 years ago and base it on that... the shocks are incredible and I would be hard pressed to tell them from a coil shock in terms of durability... and the ride, with the adjustable air-spring, I can dial that in to a "T" and still have top notch performance. Tons of successful snowcross racers on the Floats and loving them. IMO, a good dual-rate spring or triple rate coilover will have similar character to an EVOL... and the EVOL will weigh a bit less.
FLOAT3, FLOAT3-EVOL, FLOAT EVOL-R... FLOAT2 .
The
EVOL R's are in the $1000 range... These offer high tech coatings and, what I like to call, a compliance adjuster. It is called "R" for rebound, but in actuality, it is an adjuster that affects both Rebound AND Compression as it is a valve-stack-bypass-adjuster... Which is VERY cool in my opinion.... one knob allows you soften or firm up your shock.
FLOAT3 EVOL is not adjustable in terms of valving...but IS adjustable in terms of spring rates and bottom resistance (EVOL chamber) AND has the Kashima coat like the R. Those Shocks are in the $850/pair range.
Float3's are a monotube shock... They have the Kashima coat, but no EVOL chamber...Those are in the $650 range.
ALL of the "3" series shocks feature the Bleed-Shim pistons in them for better damping control.
Float2's are very similar to the Float3's minus the Kashima coat and Bleed-Shim pistions... These are in the $500 range (street price)
Float2 shocks are not a current model offering.
