Shave Primary Weight
ditch1000
I want to remove some weight from my primary weights (probably about 1/2 gram) just to fine tune the clutching on my Rk Tek Drop in kit. What ize drill bit removes how much weight???
Thanks
Grind the weight off the side of it using a die grinder. It wont take much to remove half a gram.
I use a angle grinder and take material off the back side of the weight. Get a good scale also so you can balance them at the same time, might be pretty surprised how far off a 60gram weight can be.
Stock weights
I have mds weights and just me being curious i thought ide weigh the stock weights to see how off they were and i found there up off up to .9 grams!
Ditch, iv ground mine on the side of the weight, that way it doesn't Change the cararistics of the weight, I use the side of a bench grinder, but make sure the side of the stone is not gouged and nice and even.
Get on Amazon and buy a jewelry type scale that will measure grams. I bought one last year for about $40-50, works great!
