SKU: SR99-SXCDI300 Slavens Racing
Thanks for the info guys.
So the verdict is skip the SX CDI?
I was thinking I would do a top end in it (unknown hours on it) and have slavens cut the head while its off.
I was leaning towards the Pro Circuit pipe. Worth the money?
Ooh and one more thing, run an EGT Guage! It will make life a lot easier, I've ran stock carbs with JD reccomendations, lectron and smart carb, none of their reccomended setups were close, some of them were off far enough to burn up a motor in the first full pull. Figure on spending the first few rides getting a baseline setting, carbs take work, especially on a modded bike, every bike and every environment has a different setup.
Looking for some info on other guys settings. I'm having a hell of a time getting the APT smartcarb dialed in. Like others once you get low to mid throttle openings set, it's too lean at 3/4 throttle. Damn near melted it down on the trail in. It's about to be tossed for a 450 if this keeps up.
The bike is a 2012 300xc, S3 head with SX CDI. BR8eix plug right now. Avid heater with jacket and bypass. Carb has all updates done and the Q07 rod in it.
To all you smartcarb people, tell me what your setting are. Tx
A few pics
Also I can verify the Pro Circuit pipe w/FMF shorty, Slavens head mod, and 300 SX CDI makes a difference
Stock 300s usually make around 36-39 HP at the wheel. I made 43.2 HP at 8500 RPM. My 09 Honda 450R with full Yoshimura exhaust and tuning made 41.2 HP. KX450s and RMZ450s make around 42. 14+ YZ450s and 13+ KTM 450s make 45-46 HP. KTM 500s only make around 40. So I'm happy with the 300 numbers. In the snow it is definitely more difficult to ride. You need to keep it revved up and on the pipe like a 125 on the dirt. But it seems to work well. Just doesn't have the mid range roll on torque of a 450.
The jacket works while riding. But try riding then stopping for a while. It freezes, then it's next to impossible to access the choke to start the bike back. Then when you manage to access the choke, don't think about putting the carb jacket the way it was...
