setting pc3
I need to set my throttle position on my dragon 800 with my power commander 3 I can't find the video on how to power up the sled from a battery. I just don't remember where the plug is that I run the power to ? thanks for any help
pthfndr,
If you are looking for an easy way to power up your PCIIIUSB without starting your machine, the image shown below illustrates where to attach the positive (red) and negative (black) wires. If you have a 9V or 12V battery at hand, you can run a stub wire to the connections on the face of PCIIIUSB to set your TPS. This does Not power up the sled - but only the PCIIIUSB. Setting of the TPS reading is described below.
If you can start the engine on your sled, a simple way to set the TPS reading in software is to:
- Start the machine
- Plug in your USB cable and open the Set Throttle Position window
- With the engine idling, click reset and wick the throttle quickly to wide open (clutches won't even engage).
- Click OK and done!
~T.J.
