2005 Fusion 900 electrical ussues
2005 Polaris Fusion 900. Symptoms are:
No lights.
PERC reverse does not work.
When I power with 12v battery,
Error code, 3 flashes = intake air temperature sensor. Sensor ohm checks good. Tried 2 of them, same code. With out battery, Voltage checks 4.6v. Spec is .19-4.9v.
With out battery, I checked voltage at the accessory plug. The voltage is unreadable on my meter. It varies all over the place.
The capacitor checks good.
Any help would be appreciated.
Check your Stator OHM's all of them, Might possibly be the lighting coil side has died- Does the sled even start? Have spark?
Do you know what values I should be looking for? I have a RMK repair manual. It does not show the values for the voltage regulator. Or would it be just an open circuit?
