sencondary clutch jackshaft alignment tool
R
Apr 16, 2016
8
8
3
Has anyone had their secondary clutch off yet? I'm new to Ski Doo so just curious about tools required to change the secondary spring. From watching the videos on other setups you need an alignment tool when you take the jackshaft out of the chain case. Any info would be appreciated.
Wapow
515
370
You're probably thinking of the specialty tool used to push the shaft out and holds the upper gear in place. A dowel or big screwdriver works as a replacement in a pinch. You can also just pull the cover and deal with it that way.
M
Apr 24, 2016
202
88
Yukon
These are the tools they recommend
DRIVEN PULLEY AND COUNTERSHAFT
SERVICE TOOLS
Description Part Number Page
COUNTERSHAFT ADAPTER 529 036 424
COUNTERSHAFT BEARING INSTALLER 529 036 066
COUNTERSHAFT BEARING REMOVE 529 036 065
COUNTERSHAFT SUPPORT 529 036 067
DRIVEN PULLEY SPRING COMPRESSOR 529 036 182
UPPER GEAR RETAINING TOOL 529 036 110
